LabVIEW 3D Picture Control Evaluation Software Discussion
It depends on the complexity of th e model. I once tried to display and simulate the kinematics of my robot model, it was slow. but if you reduce the complexity you can get faster result.
-Just a student-
Message 71 of 79
(4,278 Views)
lisandropuglisi wrote:
Does anybody has ever work with real mechanical object in 3D Picture Control, instead of simple primitives (cubes, spheres, etc). Because it takes to long to read the .wrl files.
The 3D picture Control is a nice tool but not nearly as optimized for such tasks as real 3D modelling software like Solidworks. And it is an entire software theorie of its own, so I don't expect NI to tackle that. Instead NI seems to be working more towards tighter integration with Solidworks, and who knows maybe they will acquire them or some other 3D modeling software some day Smiley Wink
Has happened with other software tools like HiQ, Diadem, Electronics Workbench.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 72 of 79
(4,267 Views)
rolfk wrote:
... like HiQ, ...
Rolf Kalbermatter
I have not heard (read) that in quite a while.
Someday we should put together a list of terms that have come and gone.
HiQ
BridgeVIEW
State Diagram Editor
Ben
Message 73 of 79
(4,257 Views)
Actually HiQ has not come and gone again just as BridgeVIEW at least in a technical way. HiQ was an independant software package a bit like Mathematica and NI acquired it and presumably integrated some of that knowledge into LabVIEW and CVI analysis libraries, but indeed let the original software die. BridgeVIEW was simply a LabVIEW version containing a SCADA system mostly written in LabVIEW too. They had taken some parts, such as the hystorical logging, from the Lookout software, they just had acquired some time before from Georgetown software. Later BridgeVIEW was abandoned as name but the additions that made out BridgeVIEW were released as LabVIEW Data and Supervisory Control add-on toolkit.
Then there is the SurfaceVIEW add-on which was a 3D graph add-on from Metric systems but that was so tightly integrated into the LabVIEW internas, that were in LabVIEW 3 still very much accessible, although not usable in any way from people who had not worked on the LabVIEW development team themselves. This interface allowed external code modules to have access into the LabVIEW object oriented messaging system, but proofed to be a maintenance nightmare as the LabVIEW versions evolved and the object message interface got expanded. In About LabVIEW 5 most of that interface was entirely removed from the cintools exports and as such it was not even theoretical possible for non LabVIEW developers to add such controls.
Another name was ConceptVI which was bought by NI and renamed and since also completely redesigned into IMAQ Vision. That redesign was actually a good thing as the original ConceptVI library had a somewhat special idea about how a LabVIEW VI library should look and work.
Then there is the Medium Toolkit (also called SQL toolkit) from Ellipsis software which was acquired in 1996 and resold for several years before it was completely redesigned into the current Database Toolkit that is using ADO instead of accessing ODBC.
Rolf Kalbermatter
Message Edited by rolfk on 08-19-2009 08:21 PM
Message 74 of 79
(4,240 Views)
IMAQ itself was a vision program which originated, like LV, on the Mac.  After NI bought it, they changed it to a Windows only add on to LV.  There was at least one version of LV and IMAQ which ran on the Mac.
Lynn
Message 75 of 79
(4,236 Views)
Hey guys,
National Instruments has been working with Test System Strategies Incorporated (TSSI), an NI Alliance Partner to develop a new pattern conversion tool called the TSSI TD-Scan for National Instruments to enable engineers to import WGL and STIL vector formats into PXI.   The software coverts digital test vectors from either WGL or STIL to work directly with NI 654x and NI 655x digital devices.
The software tool is available from TSSI and is included as a 30-day evaluation package with NI high-speed digital I/O PXI hardware.  You can also request an evaluation version at the link above.
To learn more about the tool, check out the following whitepaper and webcast:
Using TD-Scan with National Instruments High Speed Digital Devices (NI 654x and 655x)
Importing WGL/STIL files with the TSSI TD-Scan for National Instruments (webcast)
Scott Savage
Semiconductor Market Development Manager - Semiconductor Test
Message 76 of 79
(3,808 Views)
Hi Lynn,
The IMAQ Vision Toolkit for LabVIEW 4.1 was the one you wrote about. In fact I somehow brought it up to LabVIEW 6.1 which runs well on the latest and greatest Classic MacOS 9.2 and I still use it there on a B&W G3 Mac for a number of simple image acquisition tasks with a NI-PCI frame grabber board.
Long-timers sometimes outlive the up-shooters !
Regards and happy wireworks as always
Urs
Urs Lauterburg
Physics demonstrator
Physikalisches Institute
University of Bern
Switzerland
Message 77 of 79
(3,422 Views)
Hi all,
I am trying to make a pipe mesh using 3d object VIs in LabVIEW. I tried with numerous ways, but I am not getting the perfect shape.
Can anyone suggest me how to do this?
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 78 of 79
(3,133 Views)
I know this thread hasn't been replied to in quite a while but I was hoping one of you knowlegeble people will know how to (or better still, have an example of) exporting a 3D plot to STL file.
I can see lots of examples of opening STL files but I can't find any examples of saving to STL.
I have a scanning application that I need to export from.
Thanks!
Message 79 of 79
(2,545 Views)
