LabVIEW 5.0.1f1 installed on Windows 2000
I'm transferring LABView 5.01f1 programs from a W95 computer to a W2000 computer. I set all the software directories the same on both computers. When I open a .vi on the W2000 computer it had to search for many of the sub .vi's. I had to go thru all the .vi's and find all the sub vi's then resave them. That was a hassle and I wondered if there was an easier way to go about this but since it worked I wasn't too concerned until another user logged on the computer(Novell Network) then when a vi was opened it needed to search for sub vi's again. Does anyone have a solution? I thought that the vi path's were saved in the vi itself.
(2,540 Views)
I believe that this knowledgebase answers your question exactly.
Hope this points you in the right direction!
E. Sulzer
(2,519 Views)
