LabVIEW 5.1.1 App Builder doesn't work on WinXP or 2k?
G'Day All,
I have a client that needs some apps written in LabVIEW 5.1.1 built into exe's, but I've found that once I install the App Builder on my Windows XP and 2000 PCs, I get "dist build app image subvi is not executable" - I've tried opening the wiring diagram to fault find, but it is understandably passworded. Has anyone come across this problem, and if so, how do I get around it?
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
International Voicemail & Fax: +61 2 8080 8132
Australian Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specif
ically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(2,627 Views)
Christopher
LabVIEW 5.1.1 is not supported under Windows XP. The first LabVIEW version that we tested and do officially support under this OS is 6.1.
On Windows 2000, you may get this error if you install the Application Builder 5.1.1 on the machine that has LabVIEW 5.1 on it. Both versions have to be the same.
I Get Errors After Installing Application Builder 5.1.1 On Top of LabVIEW 5.1
Zvezdana S.
(2,627 Views)
