LabVIEW 5.1 Set Type and Creator function - how to output text format
I was given an existing LabVIEW ver 5.1 program for a Mac (I've only used ver 8.5 or higher) and asked to change the file output from Igor to plain text. The Set Type and Creator function has type = "IGBW" and creator = "IGR0". The description in the help just says it needs to be a 4 character string. What do I use for a plain text file?
(3,341 Views)
What version of the Mac OS are you using?  Can you post a screenshot (.jpg or .png) of the part of the code which you need to change?
The Type and Creator information is no longer used in OS X.
Lynn
(3,334 Views)
Lynn, Thanks. I have attached the section of code with the Set Type and Creator function. The computer is running Mac OS 9. Also, here is a link to the NI help on this: file:///Applications/National%20Instruments/LabVIEW%208.5/help/html/index.htm?glang.chm/Set_Type_and_Creator.html
(3,324 Views)
For type you can use "TEXT". For creator you can use whatever application you want. For example, for SimpleText it would be "ttxt".
(3,315 Views)
OK,  To write to a text file just use the Write to Text File+ VI.  Remove  the Set Type and Creator VI.  The file will default to a generic text file.  I do not recall what Type and Creator codes will be used (TEXT and ????, maybe) but the OS will find a text editor or word processor which can read the file.
If you need to use particular Type and Creator codes to get the file to open in a specific program when double-clicked, you need to determine what those codes are. Or if it is a small number of files you can change it manually with the Get Info mode in OS 9.
I am working from ancient memory so I may have some of the details rather fuzzy.  Let me know exactly what you are trying to do and I will try to help.
Lynn
(3,311 Views)
