LabVIEW 5.1 failure dialog.c line 273
HELP!!!
Anyone out there seen this error before?
(2,541 Views)
We at National Instruments support the 3 most current releases of our software products, so as of now we support LabVIEW 8.0, 7.1, and 7.0.
That being said,
this particular error has not been reported to us before and if you could provide more information on the crash (does it occur when running the VI, at which point the error is fired, etc) that would be helpful.
If you can reproduce the crash and have a VI that illustrates the problem, please attach the error log file associated with this crash along with any VIs, and I will report it to R&D for further investigation.
Also, I suggest you try running your VI on LabVIEW 8.0 and see if you still get the error.
Thank you and best regards,
Shakhina P.
(2,528 Views)
