LabVIEW 6.02 100% CPU usage problem
Hi!
I've executed the attached VI under LabVIEW 6i v.6.0 and v.6.02
in a Windows NT system.  When it runs under v.6.02, the
CPU usage is 100% and other programs slow down.  Under
v.6.0, however, it takes only 13% of the CPU usage.
Is there any setting that I can apply to resolve this issue?  Or should
I uninstalled the v.6.02 version and use the v.6.0 instead?
Please advise.  Thanks!
(2,795 Views)
Impossible to advise. The block diagram is locked...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,792 Views)
