LabVIEW 6.1 failure: "image.cpp" line 4336 using Win98 SE
When I open a .vi containing a graph or attempt to add a graph to a new .vi, I get a LabVIEW 6.1 image.cpp Line 4336 error, after which LabVIEW exits. I am using the standard VGA driver supplied with Win98 SE. I have tried all possible Hardware Acceleration settings. My 6.4" display only supports 16 colors and 640 x 480 resolution.
(2,510 Views)
Hello Rhodes,
I am sorry that you are getting this image.cpp error. Unfortunately, you are getting this error because LabVIEW no longer supports 16 color mode. You will have to run LabVIEW on a computer with 256 color mode or higher to avoid this error.
Jyoti F.
(2,510 Views)
