11-12-2009 03:03 PM
11-12-2009 09:59 PM
I agree with ravenfan the fonts look different. If you dont use application/dialog/system fonts, but specify a font this will not change when in the exe, otherwise the font is specified by the applications ini file (in same folder as exe with same name as exe bith ini extension). Also the Levels array appears to be floating in the development environment. I would highlight the array data and specify a font.
11-13-2009 10:39 AM
11-13-2009 10:48 AM
