LabVIEW 7.1 - An exception occurred within the external code...
I'm having this same problem in LabVIEW7.1:
http://digital.ni.com/public.nsf/allkb/C351EA63DC26054A86256B480067CA32
except that, this time, the error says:
VI "xyz.vi" was stopped at node  0x3FC of subVI "age82xx Set Output Power State.vi"
("age82xx Set Output Power State.vi" is part if a VI library for an Agilent E8254A Signal Generator.  All of the VI's for this instrument have their inputs and outputs mapped directly to an external function in a common DLL.)
If I dismiss the error and re-start the VI, it runs just fine.
Message 1 of 1
(2,586 Views)
