LabVIEW 7.1 Run-Time tries to re-install
LabVIEW 7.1 Run-Time tries to re-install or asks for the installation CD occasionally. I am not sure what triggers it, but one example is that every time I use Internet Explorer (v. 6.0.2800.1106) to go to "http://www.dailycamera.com/", it happens before the page loads. I do not have any other programs running and definitely do not need the LVRT library. What gives?
System: Windows 2000 (v. 5.0.2195 SP 3)
3 events in the Event Logger:
1)
Detection of product '{518930BE-7875-4547-B026-20B92F695781}', feature 'DataSocket.LVW71RTE' failed during request for component '{22056900-C842-11D1-A0DD-00A0C9054277}'
Note> {518930BE-7875-4547-B026-20B92F695781} = NI LabVIEW Run-Time Engine 7.1 (version 7.1.157)
Note> {22056900-C842-11D1-A0DD-00A0C9054277} could not be found in the registry
2)
Detection of product '{518930BE-7875-4547-B026-20B92F695781}', feature 'DataSocket.LVW71RTE', component '{713943EB-D52A-4905-AAB9-22542176A4B2}' failed. The resource 'C:\Documents and Settings\All Users\Start Menu\Programs\National Instruments\DataSocket\' does not exist.
Note> {713943EB-D52A-4905-AAB9-22542176A4B2} could not be found in the registry
Note> 'C:\Documents and Settings\All Users\Start Menu\Programs\National Instruments\DataSocket\' was moved in the menu. But, why would this matter since this is just a shortcut to the actual program which was not moved????
3)
Detection of product '{518930BE-7875-4547-B026-20B92F695781}', feature 'Run_Time_Engine.LVW71RTE', component '{6E92D847-3CF8-499F-BCED-DF55558CC190}' failed. The resource 'C:\WINNT\system32\lkhistdl.dll' does not exist.
Note> {6E92D847-3CF8-499F-BCED-DF55558CC190} could not be found in the registry.
(2,530 Views)
I also used to have it. I don't have it anymore, so I think I must have went to the CD and specifically asked for the RTE to be installed. I don't know what caused this, but I no longer have the problem.
___________________
Try to take over the world!
(2,512 Views)
