LabVIEW 7.1 application won't run on Win 7 64 bit
Hi
I created an application with LabVIEW 7.1 and the related installer (including Analyse VIs support). After installation the application runs on Win XP 32 bit, Win 7 32 bit, but it can't find certain analyze VI's under Win 7 64 bit.
Does a LabVIEW 7.1 application at all run on Win 7 64 bit, or is this a different problem?
(2,803 Views)
LabVIEW 7.1 is not officially supported under Windows 7 (32 or 64 bit), so you are lucky it works under 32 bit.
(LabVIEW 2009 SP1 is the earliest officially supported LabVIEW version for Windows 7, see also).
What are the exact error messages?
(2,800 Views)
Accepted by topic author Das_Swiss
The messages are that it can't find the following VIs "Mean.vi", "ReadFFT.vi". The front panel window of the application opens, but with a broken "run" button.
(2,792 Views)
