LabVIEW 7 Express newbie questions
I'm starting to teach myself LabVIEW 7 Express, from Robert Bishop's
"Learning with LabVIEW 7 Express" book. (I'm using the Student Edition
of LabVIEW 7.)
First, is there a FAQ for this newsgroup? (I found comp.lang.labview by
searching the newsgroups available on my ISPs newsserver.)
Second, a question about some of the posts in this newsgroup.
I see that many of the posters show up with email addresses of
"x@no.email". (This is especially true of people who answer questions,
some of which I suspect are NI application engineers.)
This has me wondering if there is some sort of discussion forum on the
NI website that I should know about. And if there is an NI discussion
forum, is everything there cross-posted here? (Th
e fact that some
postings appear to be responses to questions which I can't find asked in
this newsgroup also contributes to the feeling that there is some sort
of discussion taking place elsewhere.)
Third, when I start LabVIEW, my firewall (ZoneAlarm) tells me that
"LabVIEW 7.0 Development System is trying to access the Internet" and
"LabVIEW 7.0 Development System is trying to access the trusted zone".
When I go "Open -> Examples..." from the main LabVIEW dialog, ZoneAlarm
tells me "NIExampleFinder.exe is trying to act as a server",
"NIExampleFinder.exe is trying to access the Internet" and
"NIExampleFinder.exe is trying to access the trusted zone".
Since I have a legal copy of LabVIEW 7 Student Edition, I would *hope* I
haven't installed a bunch of worms and viruses when I installed LabVIEW
7, but why does LabVIEW want to access the Internet so much? And what
benefit do I get by allowing it (or at least NIExampleFinder.exe) to act
as a server? (Yes, I'm paranoid abo
ut computer and internet security.
The question is, am I paranoid *enough*?)
Thanks in advance for patience with these newbie questions, and for your
assistance in answering them.
Bob Pownall
(31,561 Views)
Yes, this Discussion Forum is actually hosted on NI's Website. You can get to it from NI's support page, or using the following link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=ni&RPAGEID=0
There's one other forum hosted by the LAVA usergroup. You can access that at: http://forums.lavausergroup.org
This also has a LabVIEW FAQ at:
http://forums.lavausergroup.org/index.php?s=bc4c1e3d13c92577b07bbae919be885f&showforum=30
Hope this answers some of your questions.
Khalid
(31,561 Views)
Khalid wrote:
< he="" provided="" answers="" to="" most="" of="" my="" newbie="" questions.="">
Thanks for taking the time to answer write. Hopefully somebody will be
able to answer my other questions as well.
Bob Pownall
(31,561 Views)
Hi Bob,
it is normal for LabView accessing the internet esspecially the Example Finder. As far as I know it uses a internet database technilogy to host and managa all example files but if you will take a look at the messages from ZoneAlarm you will see that LabView and Example Finder access localhost first and only if you explicit search the LabView webpage for examples it acchesses the internet.
But I am no developer and do not really know what the software is doing with the internet connection 😉
Stephan
(31,561 Views)
Bob,
Khalid nicely answered some of your question.
About your ZoneAlarm question: LabVIEW incorporates lots of networking functionality, it can act as web server and can use datasocket communications, etc. if so configured. As far as I can tell, LabVIEW does not access the internet, but uses TCP for some of the communications within its modules. For example, If I start LabVIEW or the example finder, netstat shows a collection of connections from/to the reserved localhost address (127.0.0.1). Example:
C:\Documents and Settings\Administrator>netstat -n
Active Connections
Proto Local Address Foreign Address State
TCP 127.0.0.1:3230 127.0.0.1:3580 TIME_WAIT
TCP 127.0.0.1:3231 127.0.0.1:3580 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3232 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3233 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3234 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3235 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3236 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3237 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3238 TIME_WAIT
TCP 127.0.0.1:3580 127.0.0.1:3239 TIME_WAIT
These are perfectly safe and should be allowed. Packets never leave your computer. Zonealarm is sometimes too paranoid.
Of course LabVIEW itself can act as web server or datasocket server if so configured. Also some of the examples demonstrate network communications.
I have a good collection of packet sniffers and other network monitoring equipment (some even written in LabVIEW 😉 ). E.g. I can record every single packet that traverses our ZyWALL 70 that protects our Lab Network from the rest of the world. I have detailed traces during starting of LabVIEW or Example Finder and they are clean. Also notice that the Example Finder contains direct links to the NI support site and thus can act as internet client. If you ever want to use that functionality, you must allow it to access the internet!
In summary, you can fully trust anything from National Instruments. There is no sleazy phone-home functionality, no malware/spyware/adware component, no hidden usage profiling, it does not even check for program updates. 😉
I have used LabVIEW for 8 years on a daily basis and had never seen the slightest indication of anything suspicious. On the contrary, National Instruments is one of the few companies that seems to do everything the correct way in this area.
(31,561 Views)
altenbach wrote:
< a="" very="" complete="" response="" to="" my="" questions="" about="" labview="">
attempts to access the Internet>
Thanks for taking the time to respond. (And my thanks to S.Klumpp as well.)
It wasn't so much that I was worried about adware/spyware/malware from
NI's LabVIEW application, it's just that (as I said), I'm paranoid and I
wanted to know *why* LabVIEW wanted access. (It wasn't intrinsicly
obvious that LabVIEW needed to access the Internet, unlike, say, an
email program or a web browser.)
I've gone ahead and told ZoneAlarm to let LabVIEW do what it wanted.
I look forwared to learning more about LabVIEW, and I can already tell
that this forum will be a valuable resource.
Bob Pownall
(31,561 Views)
Bob,
Here is a quick summary of some LabVIEW resources that will help you become a master programmer in a short time. Most has been mentioned, but I took the liberty to add some more annotation to help you decide.
(1) The Discussion forums in the Developer Zone at NI. Most are mirrored (both ways) to parallel newsgroups, e.g. the Forum "LabVIEW General" is synchronized to the comp.lang.labview newsgroup. It is not easy to decide between newsgroup and developer forum, both have advantages and disadvantages.
Newsgroups: Many people don't subscribe with their real e-mail address, because they often get harvested by spammers. If you have used newsgroups for a long time and have a favorite newsreader, you'll feel right at home.
Developer forum: Has all the content of the newsgroups, but also has some extra perks that could be useful, such as: Posters can create a user profile that can give some information on their background. The e-mail address in your profile is totally private and safe. Good posters can built up some "karma" over time, which can indicate a certain level of seniority. After a certain number of posts, you can apply to be promoted to "enthusiast". There is also a star rating system that is somewhat useless because it is not defined and users interpretation seems to vary. You can optionally give answers between 1 and 4 stars, but unfortunately only the **** rating has a clear definition for me. Some tend to think that * and ** are negative ratings, while others think that any number of stars are positive and elevate a post above an unrated.
Both support multiple attachments (for example VIs, entire llbs, or sometimes code images). LabVIEW is such a visually oriented language that many times a small diagram can make a point much better than a longwinded explanation in ASCII. (As they say: A VI is worth a thousand lines of code).
(2) The info-LabVIEW mailing list. A mailing list with mostly high-quality discussions. More information on how to subscribe is on the Info-LabVIEW home page. Depending on how much other e-mail you receive, it tends to clutter up your inbox a bit. I have recently switched it to my g-mail account, which automatically sorts the messages by topic. AFAIK, info-labview is strictly ASCII, but since the e-mail addresses are typically valid, members sometimes exchange code out-of-band.
(3) There are other online discussion forums such as the already mentioned LAVA user group (See also the LAVA home page) or the OpenG forum (OpenG Homepage).
For general LabVIEW information, don't forget the LabVIEW Zone. They also run regular conding challenges where you can submit your code entries. The deadline for the current median challenge is by the end of this month. Good luck!
(31,561 Views)
