LabVIEW 7 can't open source code based on LAbVIEW 6.1.
LabVIEW 7 can't open source code based on the LAbVIEW 6.1 with an error that some VI doesn't have block diagram and can't be converted. What to do in this situation.
(2,910 Views)
You are stuck, unless you can get the source code for the VI with the missing diagram. However, you can still open the rest of the application. Delete the "bad" VI and replace it will new code, assuming that you know how it works.
(2,910 Views)
Jim is right.
There is no way of converting/upgrading a VI to the newer version of LabVIEW without its block diagram. Below are a couple of KBs that discuss this issue:
How Do I Recover My Block Diagram If I Saved My VI with Options and Selected Remove Diagrams?
What Does it Mean When I Receive the Message "LabVIEW load error code 11"?
Feroz
(2,910 Views)
