LabVIEW 8.2.1 Runtime
It is possible to download the LabVIEW 8.2.1 Runtime engine?
This LTE runs in windows 10?
Thank you all.
Message 1 of 8
(10,439 Views)
Message 2 of 8
(10,437 Views)
Thank you.
But I need to have the LabVIEW 8.2.1 Runtime installed tu run and older executable.
It is possible to LV 2015 SP1 or later for Windows 10 and also  LabVIEW 8.2.1 Runtime engine to run the old executable. The executable will work?
Thank you.
Message 3 of 8
(10,432 Views)
Accepted by topic author Pt82
You'd have to use Windows XP for LV 8.2.1. I'd recommend updating the old LabVIEW code version and rebuilding the executable. You may be able to run Windows XP inside a Virtual Machine on your Windows 10 PC.
Message 4 of 8
(10,419 Views)
If you are using hardware that lives inside the PC, you should make certain there are Win10 drivers for it.
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(10,351 Views)
All the previous answers are wrong.
You can run labview runtime 8.2.1 on a win10 computer.
We have it working here in the company.
I'm trying to replicate it on another windows10 machine but It doesn't work.
I think in order to work, you must :
 - not have installed any version of labview
 - Install Labview runtime 2011 32 bit (even if your system is 64 bit)
I did the mistake to install other labview runtime versions. Now I have to format windows, because when you uninstall labview, it let some files hidden somewhere.
Labview installation file is **bleep**...  They are unable to remove all the files they've installed on the machine... What a shame !
Message 6 of 8
(10,062 Views)
Where can I download LabView 8.2.1 Runtime?
Message 7 of 8
(9,858 Views)
Take a look at http://download.ni.com/#support/labview/windows/runtime/8.2/
Message 8 of 8
(9,849 Views)
