[LabVIEW 8.2][Beginner]See a square signal from the microphone input (or maybe DB-9)
Hello, I would use a signal on LabVIEW which a square signal (0V or 5V) and which has a frequency between ms to s.
I would receave it from the microphone input or with the DB-9 serial port (but some people told me that is impossible so...).
After, I would see the signal on a window and also via a diode which should be green when the signal is 0V et red when it's 5V.
Thanks.
(3,052 Views)
You can use the sound card microphone input to acquire an analog signal, but be careful with the range (the amplitude of a microphone signal is very small).
The DB-9 is for serial communication, so it can’t be used for acquisition.
I advise you to buy a low cost acquisition device such as the USB 6008.
Thomas Baudouin
NI Application Engineer
Thomas B. | CLAD
National Instruments France
(3,018 Views)
Thomas B. | CLAD
(3,017 Views)
can you tell us more about the application?  Is this some form of audio measurement, or simply a electrical circuit timing signal.  With details regarding the application, we can provide a better recommendation.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,004 Views)
Hello, for now, my circuit is this.
What I would do is is a big loop with this :
A count which decreases each time the loop restart until it reaches 0 and when it reaches 0, the loop stops. I would be able to choose the number of loop in the user interface.
Actually, what should happen is :
I launch the program with a button, the count decrease of 1, on the program (the one I gave you an image above) the DTR button goes ON. Somethings will happens in an external circuit : the input from the microphone goes to 100mV (Actually, it's 5V but I will decrease it because I know that the maximum input for a microphone is something like 100mV). After some seconds, the input comeback to 0V and, at this time, I would that the DTR button goes OFF. Then, after x seconds that I can define in the user interface, a new loop starts and the count decrease of 1.
Just tell me if it's not clear, I know that my english is not really good.
Thanks.
(2,985 Views)
