LabVIEW 8.5 Bug Report: VIExecState.cpp, Line 530
This bug seems to restricted to the attached code. Any change to the VI block diagram which in turn marks the VI changed in the title bar with an asterisk. If I try to run the VI in its unsaved state it crashes with the VIExecState.cpp Line 530 error.
This is how I induce the fault using the attached code.
1. Before starting LabVIEW add "DWarnDialog = TRUE" to the LabVIEW.ini file without the quotes.
2. Open "BurnIn Shelf 2 - Shell Only.vi"
3. Click the "Run" toolbar icon code then click "Abort Execution".
4. Edit the block diagram e.g. add a free label.
5. Click the "Run" toolbar icon again.
6. This should induce the VIExecState.cpp, Line 530 error.
As this is a "warning" I have set "DWarnDialog = TRUE" in the LabVIEW.ini before starting labview. This means any warnings not critical to execution are displayed immediately. They are normally kept hidden until you start labview. Unfortunately, things like occurence notification stop working so its critical to some of my code implementations. Remove this entry from your labview.ini if you have finished debugging.
I have not found the source of the issue in my code yet. The error has been reported to NI UK. CAR reference for this error is #45703. I will keep the forum informed of any developments.
David
Message Edited by David Crawford on 04-07-2008 04:19 PM
(2,803 Views)
Hi David,
Thanks for posting this on the forums so that the community can be aware of the issue, I believe you spoke to a collegue of mine yesterday and in turn he has filed the Corrective Action Request for R&D to look into.
All the best,
(2,780 Views)
