LabVIEW 8.5 Import Shared Library include paths browse does not work?
If importing a shared DLL, when you get to the include paths, hitting the browse button, opens the dialog, and after selecting the current folder, does not display that folder path in the control.  You can manually edit this field, so there is a workaround.  Is anyone else seeing this behaviour?
Paul
(3,134 Views)
Yes, it is a UI bug. Try to delete the original path and add new one, and it will update after you change the focus.
(3,117 Views)
It does appear the UI has a bug, however, if you choose 'current folder' it returns to the path dialog and it appears empty.  Now if you click away from the dialog, the path will populate with the 'current folder' file path.  I have reported this to R&D for further investigation.  Thanks for the post!
-Bob
(3,094 Views)
