LabVIEW 8.5 high-speed camera
I'd like to take many high-speed images with a camera, and save them to a disk using LabVIEW 8.5 to take the photos and using MAX to configure the camera. The camera is a Pulnix TM-6740cl. I've posted an example program that is similar to what I want to do. It was written by two users on this forum, N_Holmes, and reut. The only difference is that in the program that I'd like to run I need to be able to change the shutter speed of the camera (although I believe that I can do this with  MAX), I'd like to be able to change the target directory (for some reason, if I change the directory with the reut program, the camera only takes 1 "frame" and stops), and I'd like to be able to save a file for each frame taken by the camera (I can only get the reut program to save 1 file.) I have LabVIEW version 8.5. If you could help me out in any way, then that would be greatly appreciated. Thanks!
(2,494 Views)
Let's consolidate these threads into one.  Thanks!
Chris Bolin
LabVIEW Partner Program, CLA
(2,471 Views)
