LabVIEW 8.6 crash on Windows 7 OS
Hi members and LV developers,
I have come across the below crash while running a vi. The program has 2 numerical indicators bound to an OPC server tags, the crash was occuring when I have more than one opc bounded numerical indicator in the while loop(haven't done any further testing). Any comments would be highly appreciated.
Problem signature:
  Problem Event Name:                        APPCRASH
  Application Name:                             LabVIEW.exe
  Application Version:                           8.6.0.4001
  Application Timestamp:                    4862fd60
  Fault Module Name:                          nids.dll
  Fault Module Version:                        4.5.4.49157
  Fault Module Timestamp:                 485a68d1
  Exception Code:                                  80000003
  Exception Offset:                                00054461
  OS Version:                                          6.1.7601.2.1.0.256.48
  Locale ID:                                             3081
  Additional Information 1:                  83d7
  Additional Information 2:                  83d7828a32307d62afcf8149d9e4c374
  Additional Information 3:                  68fd
  Additional Information 4:                  68fd6a10903ecada1d827a617af1d1f4
Thanks.
(2,994 Views)
Accepted by topic author Parny
If you take a look at this link, it seems that NI does not support LV 8.6 on Windows 7.
So if you can, either upgrade LabVIEW or downgrade Windows, you'll save yourself a lot of time.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,991 Views)
Excellent info to sort out.
I never suspected LV 8.6 on Windows7 as the LV 8.6 installation went well on the Windows7 OS and it seems to be Ok with some examples, until I arrived the crash situation yesterday.
Thanks.
(2,976 Views)
