LabVIEW 8 development environment is unbearably slow
daniel,
I've noticed the same thing when I have many, many items on my block diagram. IF you have a large block diagram, try using sub vis. If you have many subvis, try using modules of subvis.
Chris C
Message 11 of 15
(1,692 Views)
I have run into this also when moving to a newer version of LV.  You are not going to like it, but what I did was recreate the VI and the problem went away.  I think that something happened whenthe Vi was upgraded to the newer version.  Did the file size change in the newer version of the Vi?
Message 12 of 15
(1,660 Views)
I've finally solved the issue. The delays were caused by a single block 'read from DMA fifo' from the fpga module.
When replaced with a new block, as in deleting the old block and recreating it, the delays went away.
Daniel
Message 13 of 15
(1,642 Views)
Cool, this is exactly what I saw.  I think something happened during the upgrade process.  I do not know what that process consists of (maybe an NI person can comment) but I think that your code is very much at risk when upgrading.
This should reinforce the practice of backing up before changing compilers!
Message 14 of 15
(1,621 Views)
I am experiencing this problem as well.  I am not using the FPGA module, nor am I using graphs on tabs on the vi's I'm currently editing.  "Recreating" the vi's is not really a practical solution- there are hundreds of them.  Furthermore, when I tried recreating a large vi, the lag problem didn't go away.
Is there any fix or patch in the works that addresses this issue?
I upgraded my application code from 6.1 to 8.2 and starting seeing this problem.
Message 15 of 15
(1,400 Views)
