LabVIEW Application on VM
My Customer want the LabVIEW Application to be deployed on Azure Virtual Machine.
  • How to Acquire data through Azure Webservices?
  • Launch LabVIEW Executable /Any other Tools?
(2,059 Views)
I'm also curious.
my guess is if there is data to be acquired, the daq needs to "see" the  VM over the network.
(1,975 Views)
I was curious too, so I searched " labview on virtual machines?" and got a whole page of Knowledge Base articles and forum posts.  It is not officially supported due to the nightmare that would be for NI, but it should work.  No PCI/PCIe bus, but that's normal for VMs.  An important note was for licensing:  NI Licensing Policy on Virtual Machines - NI which says a VM is the same as a physical PC, so you are limited in sharing development environments or any EXE that requires paid toolkits or other paid options.
Here is an NI forum thread where there are several links describing their VM attempts:  Getting Started with Virtual Machines - NI Community
Good luck and keep us posted...
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(1,970 Views)
