[LabVIEW Bug Report] Scroll the mouse in string array will cause LabVIEW to crash
Hi,all
I found a bug when I use LabVIEW 2015.
First create an array of string constant in block diagram, and then put the cursor in one of the string:
sting array
And then when you try to scroll the mouse wheel, the LabVIEW will crash.
(3,837 Views)
I am also getting an error
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,830 Views)
