LabVIEW Command Line Interface Release Notes
I was trying to find the release notes for the LabVIEW Command Line Interface (CLI). LabVIEWCLI appears to be at version 2.1 now, but I wanted to find out what has/changed improved. Is it just part of the LabVIEW Help now since it ships with LabVIEW 2018+?
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,849 Views)
Accepted by topic author CL_eisenwr
Hi Bill,
There were no major changes with the 2.1 release of CLI and the 1.1 version. You can find some documentation in the release notes of LabVIEW 2018 and when you compare it to LabVIEW 2019 you can see than in the 2019 the is only one paragraph that describes the improvements. I am attaching the release notes of both versions.
https://www.ni.com/pdf/manuals/371780p.pdf
https://www.ni.com/pdf/manuals/371780r.pdf
Regards
(2,735 Views)
