LabVIEW Core 1 Course problem
I try to learn some more content about Labview 2020 Community Edition.  I was going through the LabVIEW Core 1 Course. It asked me to install the NI-DAQmx driver so I did.
However, I could not get the simulated device as shown in the lesson's video (attachments).
How do I correct it?  What software do I need as well?
(4,455 Views)
Are you sure you installed the full DAQmx driver and not just the run-time only DAQmx driver?
(4,431 Views)
Hello Fan,
I have installed the NI DAQmx driver only.  I have not selected any option included.
Is it the cause?
After I have launched NI MAX, it only shows connected devices.  I guess LabVIEW Core 1 Course requires a real NI DAQmx instrument.
(4,357 Views)
Accepted by topic author HKPhysicist
I see!
I have to select the Configuration option during installation.  Then, the simulated devices will be available for use from within MAX.  😃
(4,347 Views)
