LabVIEW Crashes while starting or trying to open the project
 LabVIEW crashes out while starting or trying to open the project. It crashes constantly when trying to open the project..
Why does the crahes occur and what i the best way to avoid such crashes voilations .?
Please find the attached file below.
(3,344 Views)
Does it only crash when opening that specific project? It could be that the project file has become corrupt - have you tried restoring an older version from source control or backup? (you do use source control, right?)
I would try creating a new, empty project and then add your files back in.
(blog)
(3,341 Views)
Hi Sam_Sharp
Thanks for the reply..
I use source control. I will retsore to old version and see..how it goes..
(3,329 Views)
