[LabVIEW Critical Bug Report] Resizing (Removing an Event from) a Register For Events Node Crashes LabVIEW
The attached VI shows the problem in the most simple situation I could find: resizing a Register for Event Node can crash LabVIEW.
The situation illustrates the case where there is one node outside the Event structure and one inside. A minimum of 2 events need to be registered, the idea being that RESIZING one Register for Event node should remove all corresponding events inside the Event Structure(s), as illustrated below:
As a matter of fact, it does work... sometimes (and only once).
If you are lucky, you will go through step 1-2 without crashing LV. In that case, jump to case 4 (Undo everything and retry). I have never failed to crash LV so far (2016, 64 bit).
The first time it happened to me was on the first attemp, in a large application. Autobackup saved my day that time.
(4,997 Views)
Hello X.,
Thank you so much for bringing this LabVIEW Bug Report to our attention. I have been able to reproduce the issue on my end and have submitted a Corrective Action Report to our R&D team regarding this issue. Unfortunately, at this time we do not have a workaround for this issue. Please let me know if you have any additional questions or concerns regarding this issue.
Thank you
Gabby
National Instruments Applications Engineer
(4,889 Views)
Thanks. Can you provide the CAR number for future reference?
(4,886 Views)
duplicate (slow -buggy?- site).
(4,886 Views)
The CAR number for this issue is: 601807.
Thank you,
Gabby
(4,879 Views)
BTW, there is a workaround: first delete any connections to the element in other nodes in the Event Structure before resizing the node.
That's how I got our of this nightmare situation in the first place in my rather complex project...
(4,866 Views)
CAR 601807 was fixed in LabVIEW 2017. See the 2017 LabVIEW Bug Fix List for details: https://www.ni.com/en/support/documentation/bugs/17/labview-2017-bug-fixes.html
(4,337 Views)
