LabVIEW DH+ communications
I have an AB SLC 5/04 PLC with DH+ communications. I plan to use the AB 1784-U2DHP interface for a USB connection to a PC running a LabView application.
Can LabView use the NI OPC server to talk to the 1784-U2DHP directly, or do I need to use an AB server like RSLinx?
(2,862 Views)
The 1784-U2DHP adapter creates a virtual com port that is used to connect to the PLC via the DF1 Protocol. You will find the AB DF1 Protocol driver in the NI OPC Server.
Fred Loveless
Kepware Technologies
http://www.kepware.com
(2,849 Views)
