LabVIEW DSC 2011 / OPC Client IO Server / Can I write to the OPC Server using OPC Groups?
You'll have to provide some more detail about what you are trying to accomplish, I'm not following your concept.
Message 11 of 12
(520 Views)
At a moment our LabVIEW OPC Client application was run over 3 months and 24/7. Its reads 480 TAGs and writes 130 TAGs once per second.
About the software:
I design functions to the LabVIEW VIs that supports most of all properties and methods that are included to the opcauto.dll.
After that I build the OPC Client application as we need that works using the properties anf methods.
(See more information about opcauto.dll from http://www.opcfoundation.org/)
Message 12 of 12
(476 Views)
