LabVIEW DSC Module causes my computer from hibernating or going on stand by
When ever I install the Datalogging and Supervisory Control Module under windows 2000 or xp pro it prevents the computer form hibernating, suspending, or going on stand by. It also prevents me form ejecting a laptop form it's docking station. In every case the computer locks up as it is preparing for the respective action.
Any help would be appreciated.
Can you please
tell me the time?
I never seem
to be able to find the time,
because I'm
just lost in time
(4,019 Views)
Hi Geek101
Does your machine lock up while running a DSC program? Or just merely having DSC installed on the machine? What version of DSC do you have?
Your problem may be caused by the keyboard filter driver. This
KnowledgeBase
has more information on this problem, along with a solution.
(3,992 Views)
Just simply having the DSC Module installed does it. I am using ver. 7.1.
Can you please
tell me the time?
I never seem
because I'm
just lost in time
(3,982 Views)
Hi Geek101
If you have LabVIEW DSC 7.1, then your problem is most likely caused by the keyboard filter driver. Did uninstalling that component according to the KnowledgeBase help out at all?
(3,968 Views)
It worked for the win xp pro computers and I'm trying it on my laptop (runs on win 2000), so I'll see if that works.
Can you please
tell me the time?
I never seem
because I'm
just lost in time
(3,941 Views)
It did work on my laptop, as well. Which is good because the DSC Module had also prevented my computer from shuting down at all.
Can you please
tell me the time?
I never seem
because I'm
just lost in time
(3,940 Views)
Thanks you very much for the help!!!
Can you please
tell me the time?
I never seem
because I'm
just lost in time
(3,939 Views)
