LabVIEW Diadem connectivity
Hello everyone,
Please check the link below, that gives LabVIEWDiadem Connectivity tool zip file.
[link removed; example no longer available]
In this file, main vi : DiademLabVIEW.vi has "Export Interface" invoke node for VI Reference.
Does any one has idea, How we can get this one? (As it is not available in the list.)
thanks.
(2,815 Views)
Hi LabVIEW_Vish,
The "Export Interface" invoke node property is a property that is sometimes used by R & D, and is not currently available from the invoke node methods in LabVIEW 7.1.  However, since it is exposed in that specific block diagram, you can simply copy and paste the property to use it!
Good luck in your application!
Andrew W.  || Applications Engineer
(2,787 Views)
