LabVIEW ECG AD8232 with Arduino
Hi everyone, I’m a first year student trying to display an ECG signal in LabVIEW using an Arduino Uno and AD8232 sensor.
The Arduino Serial Monitor shows correct changing values (300-800 range) so the hardware works fine, but Waveform Chart shows flat line even though Arduino Serial Monitor shows changing values
My block diagram:
VISA Configure (9600) → VISA Read (30 bytes) → Decimal String To Number → Waveform Chart
The Waveform Chart only shows a flat horizontal line. Read buffer appears empty when running.
Things I already tried:
Scan From String with %d
Spreadsheet String To Array + Index Array
Checked COM port (tried all available)
Closed Arduino Serial Monitor before running
Rebuilt diagram from scratch multiple times
What am I missing? Is there something specific about reading serial data from Arduino in LabVIEW that I’m doing wrong?
(1,312 Views)
Accepted by topic author Amwajsun
It is impossible to troubleshoot your problem from a few blurry truncated iamges.
Just randomly throwing code at it until something sticks seems like the wrong approach.
Do a google search for "Vaas definition of insanity".
SO: Change the string indicator to /-codes, attach your VI after filling all controls with typical default values, and describe how everything is connected.
(1,284 Views)
Thank you for your reply. Please find the VI attached.
To clarify the situation: the read buffer is completely empty when running. Also, the VISA resource name dropdown only shows ‘Refresh’  no COM ports appear at all even with the Arduino plugged in via USB.
The Arduino Serial Monitor confirms the hardware works correctly  values are streaming normally at 9600 baud.
How can i make the COM port appear in LabVIEW?
https://drive.google.com/file/d/1e4ftd2tzWF9hybI1TjW_v4G83bjhNSmn/view?usp=drivesdk
(1,263 Views)
Very few people have LabVIEW 2026, so please do a "save for previous" (2020 or beloa) and attach it here. (No need to share links of confusing VIs saved without extension.)
(1,238 Views)
