LabVIEW EXE on Server Stopping
I have an exe on server that is being acces by multiple computer.  I want to update the exe, by overwriting the old exe with the new exe, but my PC is staying that something is accessing the exe, so I can't overwrite it.  I close all instances of the exe, but the error persist. Is there a way to kick the unknown people off who are using the exe?  Is there a better way of doing this?  Thanks!
Kudos and Accepted as Solution are welcome!
Message 1 of 10
(4,590 Views)
     I have been searching the web and One thing I found points out that if you have already launched the web Executable.  you might want to restart then update the Web Service.  I will try to find other solutions if this does not work in your case.
Dano
Message 2 of 10
(4,572 Views)
Hello again,
the following Knowledge base I believe has the information you need.
http://venus.ni.com/nisearch/app/main/p/q/web services distributed system/
I hope this helps,
Dano
Message 3 of 10
(4,571 Views)
I can't access the link for some reason.  Is the link correct?
Message 4 of 10
(4,558 Views)
Message 5 of 10
(4,545 Views)
I can't access this link neither.  What kind of special links are those?
Message 6 of 10
(4,542 Views)
Message 7 of 10
(4,535 Views)
I can access the linke now, but i am not sure how does it relate to my question.
Message 8 of 10
(4,529 Views)
This will give you control form the host machine to kick people off the Web Service so you can update it, block others,  or modify its activity.
Message 9 of 10
(4,520 Views)
But it is just an exe on a server computer and not a webservice.
Message 10 of 10
(4,502 Views)
