LabVIEW Equivalent of 'Whos' command in MATLAB
Hi
Similar to 'Whos' command in MATLAB I wanted to list all the constant and controls (if possible) I used in my LabVIEW code. Does anyone know if its possible with any additional code or Toolkit.
Thanks in advance.
Robot Indifferent
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
(2,823 Views)
What is the purpose of this?
To answer the question, the VI Server provides the list of controls for the front panel via the Front Panel -> Controls[] property. For block diagram objects you need to use scripting. You can use the Block Diagram -> All Objects[] property. The Class Name will give you an indication of whether it's a constant. For example, a numeric constant will have a class name of "DigitalNumericConstant". Be aware that this second list includes all objects. There is no "Constants[]" property.
(2,806 Views)
Smercurio_fc
Pupose is to enlist name and value of constants n controls I used in quite a big VI, values of the constants are often manipulated to adjust the requirement. It will be good at the end if I can print them altogether.
Thank You.
Thanks & Regards,
Kunal Raithatha.
more reply back.
(2,798 Views)
