LabVIEW Error Hex 0x80DF00A
The error always occurs once I hit the User-defined Variables.
All my user defined variables were the same format. They are from the chassis to my realtime controller, and they all worked as of Wednesday, I cannot tell what changed with my project file.
(730 Views)
Solution: One of my user defined variables was failing. What I would recommend would be to slowly delete your user defined variables until you can deploy and un-deploy (successfully) with what you have.
(685 Views)
