LabVIEW Example %22Send Email using SMTP Client.vi%22 doesn%27t work - ERROR 56
LabVIEW Example "Send Email using SMTP Client.vi" doesn't work. I receive ERROR 56, some type of time out error.
(2,551 Views)
Unfortunately, you provided very little details for us to be able to help you.
Is it possible that a firewall is blocking access to your SMTP server?  What SMTP server are you using?
(2,506 Views)
There are millions of possible reasons why something doesn't work. We cannot narrow it down for you.
It the SMTP server configured correctly? Is it down or misconfigured? (Is this a public server or your own?)
Is the port correct?
How about all other settings (Security, authentication, etc.)
Does your ISP use proxies?
Do you use any security software that filters incoming/outgoing mail via a local proxy?
(2,501 Views)
