LabVIEW Excel Graph is not working right with a template
LabVIEW Excel Graph is not working right with a template? I have attached a picture below.
Also how can I have the x axis display the time in minutes?
(2,475 Views)
I do not understand your problem.  You've shown two tiny pictures, have provided no code that we can test.  There are examples showing creating an Excel Graph with LabVIEW and putting these graphs in Excel Workbooks.  I recommend you do a search (in this Forum) for "Revised Excel Example" which I believe shows creating such an Excel Graph.
If you attach your LabVIEW code (a file with the extension ".vi") and explain clearly what it is you want to do, then we can probably suggest how you can successfully accomplish this.
Bob Schor
(2,436 Views)
Thanks for the response, will do. It works now somehow, if anything ill let u know.
(2,423 Views)
