LabVIEW Executable Detects Windows Kiosk
I am creating a LabVIEW executable that will be the sole application running on a Windows 10 computer in kiosk mode.  I would like to check that the computer is actually running in kiosk mode.  Does anyone know if that's possible?
(5,054 Views)
Then this isn't really a LabVIEW question... yet.  Step one is to figure out if you can do this at all.  Once you figure that out, then you can figure out if you can do it in LabVIEW (and we can assist you in setting it up).  It may require a .NET call or something, is my wild guess.
Bill
CLD
(Mid-Level minion.)
(5,040 Views)
did you found the way to execute a labview app .exe using windows kiosk mode?
(4,724 Views)
You can point kiosk mode to your LabVIEW exe.  I had specifically wanted to know if it's possible to detect kiosk mode.
(4,685 Views)
Accepted by topic author pulidotech
Calling of SHQueryUserNotificationState() should give you that information. If the returned value is anything else than "Accepts Notification" or "Quiet Time" then it would be in maximized mode (usually this would be "Busy").
Rolf Kalbermatter  My Blog
(4,672 Views)
I finally got a chance to try that out and it worked.  Thanks.
(4,611 Views)
