LabVIEW FPGA CAR ID 4BPGP8XX
A new CAR with ID 4BPGP8XX was submitted today. I seem to have discovered a bug with numeric controls used in LabVIEW FPGA. This bug only occurs when the control is formatted as hexadecimal with some number of minimum digits and leading spaces. If you CLICK or DOUBLE-CLICK the current number, enter a new number and then hit ENTER, the control will revert back to the previous number. If you drag and select ALL THE DIGITS INCLUDING LEADING SPACES and then enter a new number, the control will act normally. The control acts normally for all other formatting options.
Message 1 of 1
(3,150 Views)
