LabVIEW FPGA Compile Worker v 12.0.0 for Linux install failing
julianms
If NI is specifying RHEL 6.3, I would go with that. Try to get that update, the Kernel you are looking for is this one
RHEL 6 Update 3 2012-06-20 2012-06-19 RHSA-2012-0862
2.6.32-279
Typically with Linux, once you have a functional system you don't want to update the kernel, so I am assuming that NI tested it on RHEL 6.3  and it worked, so I would start by getting exactly the version of redhat mentioned above.
Good Luck!
Message 11 of 11
(341 Views)
