LabVIEW FPGA: The compile worker cannot perform the compilation.
When I'm trying to compile an fpga vi. For example the default FPGA Main Default.vi of the myRIO. I'm getting te following response after(almost end of) step 5 of Generating intermediate files :
LabVIEW FPGA:  The compile worker cannot perform the compilation. The compile worker may be configured incorrectly for this compilation or it may be in an error state.
And I have no idea why this is happening.... I installed all the necessary software.
Labview compilation tools (2015) Vivavo 2014.4
Labview FPGA module 2015
Thanks in advance
Luukgr
(4,467 Views)
Are you setup to compile on the localhost?  I don't have FPGA at the moment to test with but I didn't think there was any extra steps.  According to this you need compile tools 14.4, is that what is installed.
http://digital.ni.com/public.nsf/allkb/7CF3DD1ABBE6AE5886257EFB0006E303
Also if you have an active SSP you can have NI do the compile for you.  I've never tested this myself but the next time I need an FPGA compiled I'll try it so it saves my computer from having to keep all the compile tools.
(4,422 Views)
sry my bad. Just came across the document which version to use, you also suggested me right now. I installed 14.7......
Yeah I'm already using online compiling from ni:). That works just fine.
I will accept solution if download is completed.
(4,410 Views)
