LabVIEW FPGA compilation error - 123002
I want to use the FPGA in NI veristand. Iam using LabVIEW 2023 Q3 32bit, and NI verstand 2023 Q2. I want to generate a LVbitx file for EtherCAT slave device. codes were developed but FPGA xilinix compilation not performing. facing error while compiling. getting the error code of  123002.  for Xilinix compilation using Vivado 2021.1.
(1,061 Views)
Hi Magesh003,
When compiling locally, these compilation errors can have various root causes.If you are experiencing issues when compiling using the FPGA Compile Cloud Service, you will need to follow other troubleshooting steps for Cloud compiling.
 You can use this link, to get proper information Error -123002 or -123011 When Compiling LabVIEW FPGA Code Locally - NI.
(996 Views)
