LabVIEW FPGA driver for Xilinx SPARTAN 3E Starter Board
I have downloaded the drivers for the Spartan 3E starter board for both 2009-1020 and 8.6 and I can't
get either one to work.  They work up until the point where thwy need to communicate with the
Spartan board and then I get an error, I think it's a COBS error of some type.
Dave Ward ward@suu.edu
Message 41 of 49
(3,473 Views)
Dave,
What OS are you using (version and 32-bit or 64-bit), what cable are you using to hook up to the board, and the specific error code would be helpful as well.
BradM
Message 42 of 49
(3,429 Views)
I thik the problem is why the driver in not for labview 8.6
Spoiler
Message 43 of 49
(3,130 Views)
Good day,
Can the link for the Xilinx SPARTAN 3E Starter Board driver for LabView 8.6 be available again?
Message 44 of 49
(3,019 Views)
I believe the installler located here may support 8.6 (don't have 8.6 installed to verify), note however that it is still subject to the same restrictions on use (namely, only for academic purposes)
Message 45 of 49
(2,983 Views)
Thank you so much
Message 46 of 49
(2,965 Views)
<-- If you'd like to actually thank me, there's a "Kudos" button over there...
Message 47 of 49
(2,960 Views)
Hi all,
Could I do something on spartan 3e kit board with LabVIEW 2013, I can not communicate with it via 2013 labivew version,
thanks a lot!
Message 48 of 49
(2,642 Views)
Hey hey!
I think I've arrived late to the forum cause all the links to get the spartan 3E starter board driver for LabVIEW 8.5 are not available anymore...I would really appreciate it if anybody would post it again 🙂
Thanks a lot!
Have a nice day!
Message 49 of 49
(2,501 Views)
