LabVIEW FPGA was unable to contact the Compile Server at "localhost" on port 96.
The following error occured when i am trying to compile my design on labview fpga 8.6, and the error reads as follows.
"LabVIEW FPGA was unable to contact the Compile Server at "localhost" on port 96. The server name or port may be incorrect, a firewall may be blocking communications with the server, or the configured timeout may be too low. You may reconfigure Compile Settings by clicking the Configure button or try contacting the Compile Server again by clicking the Retry button. Click the Cancel button to abort."
Can ane one help me in sorting out this error.,
Regards
KalyanSuman KV
(2,926 Views)
