LabVIEW HTTP POST VI Error: "cannot be processed at the receiver, due to a ContractFilter mismatch at the EndpointDispatcher"
This error just started happening on a different SOAP Server Service:
Other Server URLS work OK
Any pointers to fix this from :LabVIEW HTTP client end?
Anthony
(1,382 Views)
Accepted by topic author Anthony_L
This has been resolved.
I wrote this article as a solution pointer.
https://www.linkedin.com/pulse/post-http-heders-witsml-labview-client-anthony-lukindo-xptdc/
HTTP POST Headers for WITSML LabVIEW Client
Implementing WITSML in plain LabVIEW code using HTTP VIs requires that the following Headers are added before running the POST function which sends the SOAP request packet.
Cache-Control = private
Content-Type =text/xml
charset = utf-8
SOAPAction = http://www.witsml.org/action/120/Store.<User WMLS_FUNCTION>
Where: <User WMLS_FUNCTION>
Must be replaced with any one of the following SOAP Action requests:
WMLS_GetCap
WMLS_GetVersion
WMLS_GetFromStore
WMLS_AddToStore
WMLS_UpdateInStore
WMLS_DeleteFromStore
Including these headers before running the intended LabVIEW HTTP POST method helps to ensure proper response from WITSML AGGREGATE servers.
Mezintel has deployed LabVIEW-based WITSML 1.4.1 client to multiple WITSML service providers by including these headers before each target POST method.
Anthony Lukindo
(1,316 Views)
