LabVIEW: Hex 0x2 memory is full
Hello everybody,
I have encountered a problem. when I am converting Binary file to TDM file, using  NI standard example (Binary DataPlugin on demand.lvproj )
 up to 4MB binary file DataPlugin working properly and TDM file generate no issue.,
 but when I selected 6MB or 12 MB binary file I am facing Hex 0x2 memory issue
Somebody can help me?
Your Code Here_meta.vi
Your Code Here_raw.vi
(2,640 Views)
We can't debug pictures, especially since you are not even showing how you adapted the "raw" to your binary file.
(There is an infinite number of ways to structure a binary file and we of course have no idea what you have!).
(2,602 Views)
Hi altenbach,
I have attached zip folder in which you can see Binary file(.PE1) & DataPlugin code,
please run Create DataPlugin Output File.vi & check
if more information is needed to help me solve this issue, please let me know.
I have Installed below LabVIEW Toolkit.
(2,571 Views)
In NI DataPlugin manual :- channel length(values) limitation mentioned , but not mentioned maximum  Channel Group  length .
My Binary file details
Channel Group
Number of channels in Each group
Number of data points in Each channel
1534
8
128
3
1
20439
1
6
20439
(2,485 Views)
