LabVIEW: How do you create a DLL
Can someone point me to a procedure where we can create a DLL file using Labview.
  We need a SCPI (similar to GPIB) Open, Read, Write, Close as a DLL in Labview that I can call for testing using TestStand.
Idleally, I would like it to allow a faceplate for manual testing, but also answer to a call from TestStand as a DLL.
Mike
(3,784 Views)
Mike
Is there some reason you can't use LabVIEW VIs directly in TestStand?
Bill
CLD
(Mid-Level minion.)
(3,781 Views)
If you have application builder license, setup under build specification to make a shared library (DLL). It builds all the partds needed for a DLL (header, dll etc.).
Not sure you have to have it for what you are doing, but there it is.
(3,765 Views)
And what the heck is a faceplate? Do you mean a front panel? If so, then you have to manually change the setting to remove all front panels.
(3,759 Views)
Sigh... while we are at it, SCPI is not at all similar to GPIB, although an instrument may use SCPI commands over GPIB.  I sense a huge learning curve up ahead...  😞
Bill
CLD
(Mid-Level minion.)
(3,745 Views)
