LabVIEW: I need to Integrate "Smartbear TestComplete" Automation Application with LabVIEW
I need to Integrate "Smartbear TestComplete" Automation Application with LabVIEW. In LabVIEW 2013 version, there was a Type Library/ DLL available as "TestCompleteCOMMgr" and corresponding properties (e.g. ITestCompleteCOMManager) & methods could be invoked under it.
But I am unable to see them in the LabVIEW 2018 versions, I am unable to find that Type Library/ DLL when I browse for it under the "Select ActiveX Class" for the "Automation Open" Object under the "ActiveX Pallete". ( Please find the screenshot for the same attached )
I would need help to get the required "Type Library/ DLL" to be able to integrate Smartbear TestComplete" Automation Application with LabVIEW. Could anyone help me with it?
Thanks & Regards,
Saket
(3,280 Views)
HI there!
Are you using the same exact dll in LabVIEW2018? what OS are you using now? Is it possible that you were using Windows 7 and now you are using Windows 10, and the  2013 DLL has directories inconsistent with Windows 10?
Could you check?
Best,
Anyela
(3,248 Views)
Hi Anyela,
The problem is I am unable to find that DLL in LabVIEW 2018 DLL/ TLB Library. I even tried searching for it on the Internet and Smartbear Website, but with no success.
I am using Windows10 OS and have tried checking with both LabVIEW 32-bit and 64-bit versions.
So, only if I can get the DLL, is when I will be able to check the compatibility factors.
Saket
(3,217 Views)
I see... Have you tried contacting their support contact?
(3,205 Views)
Did you win a solution for this? May I know the status, please?
Best Regards
Roberto
(3,007 Views)
Hi Roberto,
I found a solution on the TestComplete Website to integrate and Run TestComplete Scripts via creation of COM Objects in C# or VB or Python Scripting language.
The COM Objects created using either of these scripting language can then be called in LabVIEW / Teststand based on what you wish to integrate it with, to run the TestComplete Project Suite/ Unit Scripts/ Routines as needed.
Link to create the TestComplete COM Objects with all the details :
https://support.smartbear.com/testcomplete/docs/working-with/automating/via-com/calling-script-routi...
Saket
(2,997 Views)
