LabVIEW Interface for cassy lab Toolkit Overview
hello
I want to realise some examples with cassy lab 2 and  labview  but i have a problemes of drivers of this interface please
Message 1 of 10
(6,352 Views)
Hi lali,
you get LabVIEW drivers (including example VIs) from the LD (Leybold Didactics) website. They come with a manual, where you will find even more explanations.
So what exactly are your problems?
Message 2 of 10
(6,345 Views)
my problem is: I have a lab cassy card and I want to fit with labview if it's possible, and I need drivers
thank you in advance
Message 3 of 10
(6,310 Views)
In addition to what Gerd already told you above, whet else do you think you need?
Message 4 of 10
(6,297 Views)
I have a lab cassy 2 card when software is not market well so I need to realized a program (labview) to uesd  this card with ordenateur and I want to make a program using labview and I need help and thank you
Message 5 of 10
(6,291 Views)
Could you please re-rwite that last message in your native language instead?
Message 6 of 10
(6,283 Views)
Simply saying you need help is not adequate. You need to be specific. Show what code you have written with details on the problem you have. Obviously you are using LabVIEW but you haven't even said what type of experiment you want to do.
Message 7 of 10
(6,282 Views)
voice acquisition and charge and discharge of a capacitor
Message 8 of 10
(6,276 Views)
Hi lali,
so you should start by installing the LabVIEW drivers made available by LD (the manufacturer of your DAQ hardware).
Then you should start with some free LabVIEW tutorials offered by NI on their website.
Then you study the example VIs coming with the driver (if there are any). And you should read the programming manual for your hardware.
After all this work you start with creating your own LabVIEW VIs, which call the driver functions in the right manner…
Message 9 of 10
(6,246 Views)
thank you
Message 10 of 10
(6,226 Views)
