LabVIEW Internal SCC broken & files are locked
I'm working with LabVIEW 6.0.2, using the Internal SCC System. I've lost my SCC storage and I'm not likely to recover it. I've got local copies, but they have been locked by the SCC system. I am searching my archives for unlocked versions.
The question: Is there any way to unlock the vis without the SCC system?
Certified LabVIEW Developer
(2,530 Views)
To unlock a VI manually you go in VI Properties>Security and check "Unlocked". If you have a lot of VIs, make an utility that scan all VIs in memory (load your project in memory) and use the VI Server method "Set Lock State" to uinlock the VI.
You may also need to remove the "Read-Only" VI files attribute.
LabVIEW, C'est LabVIEW
(2,530 Views)
