[LabVIEW] Interpolation of 2D array with 1D xi
I have a set of data similar to the following example:
001    5    2,35    1,45
002    -5  2,21     1,68
Now I have a given value xi for the third column, say xi=2,30
As this value does not match an entry in my list I want to interpolate. But not only do I want to interpolate column 3 but also the adjacent columns 2 and 4 respectively. The output of this routine should be an array like
1,43    2,3    1,53
Is there a nice and easy way of handling this w/o using many loops and a ton of functions?
Thanks a lot!
(4,089 Views)
I don´t think there is a ready to use solution fo your problem in LabVIEW.
But can you please explain more clearly, by using indices, what you try to do?
regards
M. Brauner NIG
(4,060 Views)
There a two function on the array pallete that work together.
Threshold 1D array and Interpolate 1-D array.
Slice out (index array) the collumn/rows you will use, use the Threshold then pass the fractional index to the Interpolate.
"Lather rinse repeat" (do it in a For loop with an auto-indexing output tunnel).
Ben
(4,054 Views)
